Swap engine cave to cthe
Hello
That's my cell engine is dead
I would like to swap to cthe Engine .
Do you have any advice ?
Easy to do?
 Tanks
On 18/05/2020 at 21:03, Arold10 said:
Hello
Easy to do?
 Tanks
Have you purchased have the CTHE engine? Its a straight forward swap.....My CAVE was replaced in 2012 with the CTHE engine however the ECU still flags up as CAVE on VCDS, From what I gather some early engine replacxements byt skoda were provided with an ECU update and some weren't?
Apart from that heres the differences the CTHE engine has:
03C 145 702 B - col. scar. tubocomp. gas scar. - 03C 145702 P
03C 133 062 D - combined control butterfly - 03C 133 062 AA
Inherent to the oil pump, oil filter, oil cooler
03C 11 121 M - pinion - 03C 11 121 J
251 N 1115 03C - 03C suction pipe 251 1115 AE
03C 103669 E - cover - 03C 103 669 H
Inherent in 'camshaft, valves adj. Camshaft
036 109 411 H - lever drag roller - 036109411 K
03C 107 065 BL - Complete piston - 03C 107 065 EC
inherent to the head cylinders that
03C 103 475 03C BC cylinder head cover 103 475 DC
Translated it Becomes this:
03C 145 702 B - col. scar. tubocomp. Gas scar. - P 03C 145702
03C 133 062 D - throttle control unit - 03C AA 133062
251 N 1115 03C - 03C intake pipe 251 1115 AE
Inherent in 'camshaft, valve adj. camshaft
036 109 411 H - roller lever drag - 036109411 K
03C 107 065 BL - complete piston - 03C EC 107065
inherent to the head cylinders That
BC 103 475 03C 03C 103 475 cylinder head cover DC
Edited by Mickmartin
Thank you very much for your answer.
Yes, I found a complete engine. Cthe
