Octavia MK3 VRS TSI 2014 reverse non-Cambus LED change VCDS coding
I im trying to replace reverse standard bulbs with non-Cambus LEDs. I dont want Cambus because they heat up. I have searched this forum and googled and havent found direct instructions for the VCDS coding i need.
I have found that i need to change Leuchte28RFL LC11 to 43-allgemeine LED and Leuchte29RFL RA64  to  43-allgemeine LED but i dont own a VCDS and have to borrow it and i need direct path to these settings.
After a lot of searching i think the VCDS setup should be like this:
09-Cent. Elect. / Security Access – 16 (code: 31347) / Adaptation – 10
Then you search for:
Leuchte28RFL LC11 and change from 18 -2*5W to 43-allgemeine LED
Leuchte29RFL RA64 and change from 18-2*5W to 43-allgemeine LED
Dimmwert AB 28 8 and change from 100 to 127
Dimmwert AB 29 5 and change from 100 to 127
Do you have to change dimmwert from 100 to 127 for both?
Like you have to change ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 from 100 to 127 for LED licence.
Can someone confirm that this is correct path and changes for reverse bulbs change to non-Cambus LEDs for error free?
15 hours ago, SC03OTT said:
I did the above this afternoon. Both working fine with no errors.
Ok il try tnx :)
i have already changed interior, side mirror and licence plate with LEDs. I have replaced  footwell bulbs with blue leds and it looks really nice :)
Did you change Dimmwert to 127 for both to?
Leuchte28RFL LC11-Dimmwert AB 28 set from 100 to 127
Leuchte29RFL RA64-Dimmwert AB 29 set from 100 to 127
Do you have to change Dimmwert to 127 for LED?
