Hello folks.
Just browsing on Google for info on LED replacement bulbs and chanced upon this forum, bearing in mind I have never used/participated in one before it seems a really great way to share info.
I was about to browse thro' the tech forums for info on getting at the side repeater indicators bulbs as I might as well replace them with LEDs as well, (I have a 2001 reg Fabia 1.9 TDI) but could not see any obvious way to gain access, looked in the footwell, grovelled under the wheel arch (don't laugh), under the bonnet, outer lens creaks a bit when a bit of judicial prising was applied but no movement, visions of bits of plastic littering the driveway!
Can any of you good people help??:confused:
Cheers all, GHOG...
Welcome to Briskoda
Thanks for the welcome Johnny, found the answer to the repeater bulb access in one of the tech forums, (thinks..to myself, look first, then ask IF you can't find the answer!!!)
Like your quote... just off to take a bath.
Cheers all,
GHOG.
Thanks for the welcome Johnny, guess I should have looked first instead of asking the question as I found the answer in one of the tech forums..oh well back under the wheelarch, liked the quote by the way.. just off for a bath....
Welcome to Briskoda :wavey:
I'm sure someone will be along in a moment to answer your queries
