15"x8" rims.
Would this ve a succesfull fit. A friend og mine Will give me his old rims. But cant find if they Are to wide for my citigo.
IT has stock springs etc.
What were the wheels on?
You could modify the wheel arches to cover the tyres.
But you need the correct PCD 4x 100, (centre bore 57.1 & the standard wheels are a 35 offset i think.)
Center and 4x100 fits. Old Nissan micra they sat on
Try 1 on then.
From memory mine are 7j which is just on the limit, so you'll probably be able to push 7.5 at the most, I don't think 8 will fit, but as above try them on for size and see if they clear the running gear and suspension okay
Well picked Them up. They Are only 6.5 but i think they still Are to wide when i get tyres on...
I reckon they'll be fine with tyres!
Will they fit tells as the picture shows.
I must go messure up the car
Don't forget that tyres protruding beyond bodywork are illegal, as well as being a pedestrian hazard, but as said above, you'll be fine with wheel arch extensions.
Just as well the rims are not crazy wide as that can reduce grip especially in the wet, given there is a bit of a sweet spot for weight/force versus area of the tyre's contact patch.
