Skoda fabia clicking nosie when turing
Hi everyone I have a Skoda fabia 1.4 2005 petrol the problem is when im driving slow and turn left or right it starts a clicking sound but not all the time some days not even once but sometimes all the time when i turn left or right if i dont accelerate while turning there is no sound . I read its the CV joint but everything looks in good condition apart from outter track rod end on passenger side looks flat but no grease leaking. I did change the anti roll bar links as one was damaged thought that was the problem but its not. Thanks in advance
Definitely the CV joint, since it's hidden under a rubber boot looking at it tells you nothing at all.
If its clicking then it needs replacing.
Thanks which side do you think i have replace
Get under the car and give each driveshaft a good shake, it should be obvious which joint is loose.
