Window regulator
6 hours ago, Blackout656 said:
Hello I have exactly the same problem with mine I just found something on u tube I typed superb 11 window regulator, then look for window stuck open I hope this helps kind regards nigel
That video is for a Octavia which is completely different
Thanks for the replies, it is indeed for an Octavia.However I have found another video on YouTube that shows the process from start to finish,
Superb 11 wymiana mechanizmu podnoszenia szyby
Michal Czerwinski
Hopefully this will help someone else out too 👍
  • Thanks 2
I did this last weekend and found that the video was a great help.
Only thing I would add, is that to replace the outer white round plastic inserts that hold the window to the mechanism I put a screwdriver thru their centre with a socket behind the insert. This allowed me to centre the insert and then tap the socket with a screwdriver to push it home. For the inner insert I put it on a long woodscrew as this gripped without opening it up and just pushed it straight into place and undid the screw.
Michal Czerwinski
Great find
