Skoda Octavia 2012 window Passenger issue
good afternoon
the passenger window is somewhat strange.
it doesn't always happen!
when we want to close, we press the button and it closes completely on its own, but sometimes it goes up just a little and opens again on its own. what i do to get around the situation is to close little by little until the end. but when I neglect to open it completely and I have to repeat the whole process until I can close it completely.
it's very annoying even when I'm away, when I want to close the windows with the key. sometimes it stayed open at night thinking it would be closed.
can someone help?
I tried to put wd40 in the gutters but I don't know if it solved, because it doesn't always happen.
thank you
If you try to close it manually in one go (pulling the switch half way instead of all the way) does it go to the top?
When you close it with the "one touch" (pulling the switch all the way up) does it rebound just before it closes as if the anti trap mechanism is kicking in?
