Mk2 Octavia 1.9 turning over but not starting
Hi all,
Hoping someone else has came across this issue and is able to advise please.
My 2010 mk2 Octy 1.9 tdi has recently developed a starting fault where is cranks (very fast) but doesn't start. At first I thought it might be the fuel pump in the tank but I can hear it priming when the ignition is on. It ran absolutely fine before this starting issue.
Plugged in the fault code reader and it came up with 5 codes:
1 - powertrain data bus missing message from instrument cluster (cleared codes, tried starting again and this did not reappear)
2 - Glow plug for cylinder 1 open circuit
3 - Glow plug for cylinder 2 open circuit
4 - Glow plug for cylinder 3 open circuit
5 - Glow plug for cylinder 4 open circuit
(All Glow plug open circuit faults reappeared after clearing the codes and tring to start the car again).
At first I thought it was a fuel issue, but after seeing the codes for all 4 glow plugs, I'm thinking it may be an issue with them / the glow plug unit? Also thought about the camshaft / crank position sensor, but there is no code showing for this.
Would really appreciate any help / advise please.
Don't waste time and money fixing the glow plugs, the 1.9 starts fine without them.
