Dual Mass Flywheel & Turbo at the same time?
Hi all.
I own a 2009 2.0tdi with 130,000 miles. The DMF is on its way out and after a turbo Mr Muscle clean which did help a lot I'm still noticing it trying it's best to go into limp mode. Whilst the car is in bits for its DMF is it worth replacing the turbo at the same time with a reconditioned unit. Can anyone advise on price for turbo replacement?
If I decide to do this and buy one from Fleebay are there any part numbers I should be looking out for so the turbo is a compatable fit. Thanks all.
Why do you suspect turbo?
See my post:
Hi MicMac.
Without going into detail. Usually carry on with limp mode, going up slight hill, hovering around 2000rpm, put your foot down, clunk limp mode. Pull over, turn on off again, back to normal. Did the Mr Muscle turbo clean, worked a treat, but a few months later it's just started hicuping or missing a beat just around same rpm again like it's almost trying to go back into limp but then pulls out of it again. Not doing Mr Muscle again. Seen some reconditioned turbos on eBay around £240 and thought whilst the engine is in bits how much extra effort would be required by the garage to replace the turbo, also really don't want to spend twice with labour pulling the engine in bits again or have the turbo brake on me after I've spent money on the timing belt and DMF.
Edited by JamesD1976
