Central locking switch replacement?
Hello,
On my central locking switch only the lock icon lights up, the open door icon remains off. I am interested in replacing it, but it seems pretty hard to do this.
Does anyone know how to replace it? Is it necessary to dismember the center console?
I'm talking about this one:
Thank you!
I think you use the same method as Luca3 needed, with the seat heater switches... You gently prise it out with two small screwdrivers, one each side. Better still, try using plastic pry-tools as they will be less likely to damage anything. You might find it is dirty or a bulb is blown but I think they may be LED bulbs and its most likely easier to  just swap the whole unit. be sure to get a Skoda one as a VW one will be red lights, Skoda are green.
Edited by mrgf
Did Luca succeed? I searched for his post but i didn't found it.
I don't want to damage the central console, i'm little scared.
His query is on the lost with the title please help me!! His avatar/username is Luca3, (I revised that on my last posting).
I am thinking he still has to do it but I am quite sure you just gently lever the switch out, a bit at a time. Be gentle so as not to break any locating clips or to slip and scratch the plastic surround.
