Sound Disabled?
So I have just got back from my weekly shop to Aldi and on the way there Radio all hunky dory but when I get in the car to come home after my first face Mask shop the radio won't play! It has a red line through the volume control.
I pull over on way home and spend five minutes looking at options to see if I have disabled it, but no joy.
I get home and have a google and find the 10 second press button down to reboot so I pop out to try it and radio and sound all good again!!! The gremlins are a tad annoying with this car...
Anyway another item to watch before warranty runs out next year...
Anyone else have the problem? I will try the 10 second hold start button (volume control) to re-set to see if that can cure it when (if) it happens again.... I even trawled the manual but that is like trawling treacle not particularly quick or useful.
You didn’t unwittingly press the ( mute) LH scroll button on the steering wheel ?
I found that button in my 5 minute stop and it showed a different icon showing sound disabled, switching it on and off did not solve the issue.
The volume symbol had a red line through it on left of display. The mute shows a symbol top middle of the display.
I should have videotaped the problem, will do next time...
Someone over on the Superb forum had the same problem - turned out to be connected to the loss of the DAB signal - swapping to another station or FM fixed it......
Thanks I only have radio 2 set up I will get some others set up to the check if it happens again.
