No Injector Pulse
Hi
Octavia with 225000Km just purchsed "no history" fails to start "towed in". Scan shows P2015 which should not cause this, however I ordered the Repair Bracket from DieselGeek for the aluminum manifold.
I did not see a needle lift sensor on injector 3, how then will the ECU knows the "fire" sequence?
Snap on data:
Coolant Temp:                                                         11
Engine speed(/min):                                               161
High fuel pressure current value (bar):              232
Rail pressure regulation status:                          2
Fuel pressure regulator valve specificed value rail pressure (bar😞 304
High fuel pressure control deviation:               18
Fuel pressure Regulator valve duty cycle (%): 25.6
Hgh fuel pressure specified value (bar):          280
No pulse showing on the scope at the injector drive wire.
Where would be a good start to investigate and fix this problem?
Many Thanks
