Epc light
I have a Fabia 1.4 classic (automatic)
The engine management light is permanently on and when I'm driving down the road the epc light comes on the dash and the car goes into limp mode.
If I turn the ignition off then on again the epc light is off but the engine management light stays on.
I've had 2 diagnostics done on the car and both times found no fault codes, does anybody have a clue what the problem is
The problem is the garage doing the scanning, it's almost certainly a coil pack but there should be a code for the misfire.
  • Sponsor
Invest a few pounds in a suitable cable, download VCDS-Lite and you'll get better info yourself than you have got from the first two scans.
