Location of Exhaust Gas Temperature Sensor No3
EGT Sensor #3 has failed on my 2010 Octavia II VRS Diesel. VCDS reports "Exhaust Gas Temperature Sensor; B1 S3 P242A - 000 - Malfunction" and I get the flashing coil and "Engine fault- Workshop". Despite lots of searching (including BriSkoda) I'm having trouble finding out where it is. Can someone help, please?
its about 1/4 of the way down the cat
Er - thanks AMD87 but it's a diesel.
  • Sponsor
Probably item 15 here: https://skoda.7zap.com/en/cz/octavia/oct/2010-663/9/906-906015/
As opposed to items 10 or 12, which logic suggests would be temperature sensors 2 and 1 respectively?
I would expect AMD to know what he's on about though, and if you look at this diagram, it does refer to a cat in the title: https://skoda.7zap.com/en/cz/octavia/oct/2010-663/2/253-253063/
Hope I'm picking the right engine code diagrams for your car.
Diesels still have cats
Sorry must have misunderstood, my bad.
Thanks for your help guys. Found it - almost, but not quite, inaccessible - on the front of the DPF (?) behind the oil filler tube. Changed it and no more flashing coil! Engine fault light still on, but I guess that will go away in time. If not I'll get the VCDS out again!
