Retrofit flat bottomed steering wheel mk3
Seen a couple of forum posts on retrofitting steering wheels on mk3 - as I can recall that was straight swaps for wheels without dsg paddles to similar wheels with dsg paddles.
Stumbled across this https://www.cars-equipment.com/en/shop/flat-bottom-steering-wheels-11/oem-3v0419091ad-bgw-flat-bottom-heated
I currently got a 2017 mk3 with heated wheel, but without the paddles. Should this be a straight swap - or do I need a new clock spring etc?
Cozmo, Skoda newbie.
Straight swap for DSG paddles.
You would only need a new clock spring to add a heated wheel.
Thanks.
My existing wheel is already heated - do I still need a new clockspring?
No (just if you wanted to add a heated wheel).
Just make sure you buy the right steering wheel - with the heated elements and the DSG paddles.
Thanks man.
