Coil overs
Will 2wd coolers fit the 4wd as they only list them for 2wd or will any other coil overs fit of a different vag platform
Coil overs
If sure if you search through the BossFox 700+ BHP Yeti vRS project he fitted KWv3 coilovers.
Golf mk 5 fronts and AudiQ3/ Tiguan rears as there was no dedicated kit for Yeti.
Edited by Kenny R
You will need check the front hub size are correct for your car as front shocks come in either 50mm or 55mm sizes.
