Air pump
The relais (marked 100) that powers the secondary air pump is powered from the ECU (I expect) continuously. I guess it should stop within 1 - 2 minutes, but it does not.
This has damaged my relatively new pump.
Is there a sensor that tells the ECU to stop powering the relais?
The relais is OK.
Octavia 2002 1.8t  AUM
Thank you
