mk2 tfsi ECU Problems - who can help
Hey guys sorry about the long post.
I only recently got my VRS but have encountered some problems and figured this was a good place to research as i have already learned so much buy reading through old posts. There has been a lot of good advise to similar issues by Shark Performance so i figured id contact them only to discover they no longer seem to be trading. Below is the message i was writing them before i discovered they were not active or maybe being a new member i am unable to PM yet but would be very grateful if anybody could help or point me in the direction of someone who can help.
Hi,
I am having some problems similar ( but different ) to this post https://www.briskoda.net/forums/topic/155671-new-ecu-required-really/page/2/ and am at my wits end trying to figure it out  and wondered if you may be able to help.
I have added a list of fault codes i have obtained using obdeleven to scan the vehicle at the end of this message . The symptoms i am getting which are progressively getting worse is the car is running very lumpy on start but and keep having esp and traction control lights coming on dash, the car seems to be in a limp mode and down on power not reving past 2500rpm  and cutting out more and more regularly.
If I  pull over and restart car or scan and clear codes car might run ok for 5 - 10mins and will then flash warning lights again and go back into limp mode.
At this point we have fitted the following from a know work running car but to no avail.
  • accelerator pedal
  • throttle body
  • Cam position sensor and actuator
My next step this evening is to remove the ecu and check for water damage but not hold much hope as all other features seem to be working ok.
I only have the car a few weeks and have covered about 1000 good miles in it before this started, I know the car is definitely remapped by a previous owner but i don't know by who or what has been changed.
I wonder is there a way i can tell if there is a software update for the ecu or weather you think it would benefit from being re flashed and if this is something you could do if i was to send you the ecu.
Date: 2020-09-11 13:13
    VIN: TMBUF61Z478011420
    Car: Skoda Octavia RS
    Year: 2007
    Body type: Saloon
    Mileage: 314780 KM
01 Engine
    Software number: 1Z0907115A
    Software version: 0040
    Hardware number: 8P0907115B
    Serial number: SKZ7Z0F3672671
    Long coding: 0203000318070060
    Trouble codes:
        P0221 - Throttle/Pedal Position Sensor/Switch B Range/Performance Implausible signal
            static
                Priority:  0
                Frequency counter:  3
                Driving cycle: 255
                Mileage: 314693 km
        P0121 - Throttle/Pedal Pos.Sensor A Circ. Range/Performance Implausible signal
            static
                Priority:  0
                Frequency counter:  9
                Driving cycle: 255
                Mileage: 314693 km
        P1545 - Throttle valve control system Malfunction Implausible signal
            Intermittent
                Priority:  0
                Driving cycle: 255
                Mileage: 314753 km
        P1602 - Power supply terminal 30 Voltage too low Lower limit not reached
            Intermittent
                Priority:  0
                Frequency counter:  1
                Driving cycle: 255
        P1559 - Throttle valve control unit Malfunction in basic settings Implausible signal
            Intermittent
                Priority:  0
                Driving cycle: 255
                Mileage: 314767 km
        P1564 - Throttle valve control unit insufficient voltage during basic setting Lower limit not reached
            static
                Priority:  0
                Driving cycle: 255
                Mileage: 314767 km
03 Brakes
    Software number: 1K0907379AC
    Software version: 0101
    Hardware number: 1K0907379AC
    Coding: 0004738
    Trouble codes:
        01314 - Engine control module (ECM) Please read DTC
            static
01 Engine
    Trouble codes:
            static
19 Gateway
    Software number: 1K0907530K
    Software version: 0178
    Hardware number: 1K0907951
    Serial number: 31001066180603
    Long coding: 7D3F070007002303
    Trouble codes:
        01044 - Control module incorrectly coded
            static
                Priority:  1
                Driving cycle: 37
                Mileage: 314692 km
01 Engine
    Trouble codes:
            static
