Help needed, electrical problems
Hello, I am having troubles with my 2003 Octavia VRS.
The engine light and the ESP light are on.
I have tried to change some relays and checked some ground connections under the battery and under the windshield by the ECU-box. Any suggestions? Thanks in advance.
These are the fault codes I have on the car:
  01 Engine electronics:
     Fault codes:
        P1425
        P1117
        P1435
        P1421
03 Brake electronics:
    Software version: 1C0907379K
    Software version: 0103
    Coding: 0021505
    Fault code:        01314
To make it easier, here is what the codes are:
P1425 VOLKSWAGEN - Tank Ventilation Valve Short To Ground
P1117 VOLKSWAGEN - HO2S Sensor Heater Circuit Short To Ground Bank 1 Sensor 2
P1421 VOLKSWAGEN - Secondary Air Injection Valve Circuit Short To Ground
01314 - Engine Control Module: No Communications
