1.9 tdi pd130 solid Amber oil light?
Can anyone shed some light on this,  set off to work and about 8 mile into the mostly motorway drive doing 70 the oil can light comes on with a beep.
Solid Amber.
Oil level is max
Coolant is fine and no mixing of either.
No smoke or strange noises but a loss of power.
Scanned with vcds and couldn't find any faults?
Only way I got rid of the light was to unplug the battery.
The light is no longer on.  I have used my other car for work tonight just incase and also because in the same trip to work one of the ARB drop links popped......
Billy
Edited by billy2981
On 16/09/2020 at 19:13, billy2981 said:
Solid Amber.
Oil level is max
Dunno for sure but if the oil level is good I'd suspect a bunged up oil pickup, which is a sump off job to confirm and cure if I'm right.
