Window switch reversed control
Hi,
I have a 2011 Octavia MKII
I replaced my Window motor (aftermarket unit, same part 1T0959701T I ), Right hand side ,drivers front.
After installing the aftermarket unit I now have reversed switches and some unexpected behavior from my door controls.
Left front button - control right front window
Right front button - control left front window
Rear window buttons dont work
Lock rear windows control button - opens 3 windows fully
The mirror adjustment knob is also reversed - and directions are not correct
L moves the right mirror
R moves the left window
I have checked fuses, and wires / bellows and all looks good.
Please help, what should I do?
Is this something I can reset from the
Do I take the control module from the old motor?
I guess I could drive it as is, not that big issue I think.
Thanks.
Problem solved,
It was very easy to separate the motor from the controller card.
Put the old card with the new motor and everything is working and out should again.
