Headlight Bulb Help
Currently own a Fabia 1.2 10 reg.
Looking to get new headlight bulbs. This may sound like such a stupid question (it is😂) but does anyone know if the bulb is a 2pin or a 3pin. I've tried looking for it in the car manual but had no luck.
I can obviously take the headlight out and check but I'm too lazy if I'm totally honest. I just want to buy the bulb and change it straight away.
And any recommendations for the bulb light. Looking for something quite bright and powerful. White light as well.
Any help is appreciated. If not, totally understandable 😂
It depends what headlights you have, I changed mine and it was a different bulb type. Can you attach a picture of them?
I believe they're h4 then.
I can double check in a couple of hours when I get home though, save you buying the wrong ones
That'd be great thanks!
If it helps, they are reflector lights and not projector lights. (Projectors have a kind of globe-looking thing inside the light). Projectors use H7's, which have one filament per bulb. H4's have two filaments, a dipped and a main beam. I think this is what you have.
Edited by mrgf
