Airbag and canbus problem
Hello friends
I replace the head unit bolero to china android multimedia with raise decoder for can bus, every worked perfect for 1 day and then it stopped to work, leaving this problem I had to replace coil spring and replace the singel stick to add cruise control.
After I clear the error reports The airbag lamp turned on after 30 km drive.
May I upload the obd scan with error to under stand what the problem with canbus that include android device too or airbag?
Log-6486373-TMBLD85L2B6043712-141870km-88153mi-10.txt
Forgot to say the android work ok but without cabus option like door open or parking sensor.
Need to update the VCDS lead to get all the information but that's some list of errors.
I would disconnect the head unit and whatever CAN bus device you have, clear everything down and see what's left. Can't see the wood for the trees in that lot, but something is upsetting the CAN network.
Edited by Tech1e
Thank you my friend, will the software update cost money?
It's not the software. The interface is out of date for the age of the vehicle.
Amongst all that there but one positive:
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels:
3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Serial number: 2149720
Coding: 800000
No fault code found.
Maybe remove that before throwing the rest of the car away :D
Sorry but I dont understand, I bought new interface and successfully coded the new cruise control stick. Why wont it work?
3C8-959-537.CLB
Coding: 800000
What is that part? I see only numbers😵
