pollen filter clips
hi i have a fabia 2014 reg now i want to no if there is 2 pollen filter  clips on the the cover or just 1 clip i have 1 clip on on it if there is 2 were can you buy them many thanks
One slides forward and one slides back. I checked the condition of the pollen filter on my Roomster which is similar and could I get the front to side forward and locate no way. The filter is only secured by the back clip.
Two clips is correct. Have a closer look as it may have been pushed to one side or even fell under the carpet/mat. They can be a pain to locate properly so be sure the filter is pushed in properly and it should be possible to slide both clips in their place.
many thanks gents for sorting this problem out i will have a look under the carpets and in the car if no 1 can be found i  will buy  1 but £12 for a small bit of plastic  christ rip off
..,Tis a bit steep seeing as the cover and two clips can be purchased on the "Bay"  for around £20 brand new!
