Key problem
Hi. This is my first port on this forum. I have a yeti 4*4. While using vcds 12.12 today, accidentally pressed "yes" for "erase all learned values". Thereafter, the key has stopped locking/unlocking the doors. It only starts the car. Manual locking by inserting key in the keyhole is also possible.
How should I solve this issue? Is there any way around it?
Synchronise the key as follows. › Press any button on the remote control key. › Unlock the door with the key in the lock cylinder within 1 minute of pressing the button.
Hope that works for you?
Is there not a backup saved within VCDS, usually anything that can change values will save a backup first.
Edited by Urrell
If he were using a genuine tool then yes, but alas...
Tried many times. Did not work.
No.
True.
