USB sockets
The day I change my Fabia Estate for whatever I get draws near.  I've just discovered the cars I'm thinking of do not have 12 volt fag lighter sockets -- only USB-C. You can get USB to 12 volt female socket converter adaptors.  Please does anyone know, are all USB outlets the same size. None of the convertors say what  USB type -- B or C, they are.
Or is there any other way of using my Tyre pressure pump or Garmin. Progress eh?
Thank you.
Do you have a link to one of the adaptors? They should state what type of USB connector they have normally either Type A, Mini, Micro or Type C.
Probably a fairly easy job to add a 12v socket somewhere, just a piggy back fuse from the fusebox and an earth. Quite a few people fit one in the boot when there isn't one as std.
