warning lights !!
Hi All,
Mk1 Fabia Vrs Se 2007
Driving slowly around town today and three dash lights came on for a few seconds accompanied by a few beeps ,,, i'm pretty sure it was the abs light, the handbrake light and one other, they were all def on the right hand dial. Car didnt stop just kept going. This happened three times at about 2 minute intervals.
Any ideas ? Should I be worried ?
Si
  • Sponsor
Check the brake fluid level.
Fault code check, probably a weak ABS signal or a wandering wheel bearing.
Thanks guys,
Could it be a weak battery ? I dont think it has been changed for a long time. Easy place to start ?
Si
Solved this , changed battery for new higher rated man sized unit,,,,,, everything good :-)
