BBY lambda probe 1 pinout
Does anybody have the pinout of the lambda probe that is between the engine and the catalytic converter? It's a 6 pin connector.
I used to get this stuff from cardiagn.com but now it seems to be broken...
It's like this. The blue/red wire comes from fuse 9, which is live any time the fuel pump relay is on.
Thanks @Wino. I am interested in the signal wires which seem to be 6,5 and 3.  6 and 5 seem to have the same color code which is weird. Do you have any idea how the signal transmission works? E.g. I see 0.42V in VCDS which wire has this voltage?
I agree, I've not noticed that before.  Wonder if they are really the same colours or if it is an error in the diagrams.
Not sure about the way it works.
