All about bulbs and LED's
Ok folks with winter fast approaching I thought I'd check my bulbs, as I lost a side light. Done that with the following LED, which is looking good. However, I wonder if folks have tried some of the other bulbs, mostly refering to rear cluster with LED and if so, what did you use?
I am concerned rear cluster is going to be a bit more critical that side lights which is why I am asking!
Side lights I chose:
https://www.ebay.co.uk/itm/LT-EE-WO-LN-2PCS-T10-W5W-5630-10LED-CANBUS-NO-ERROR-AUTO-CAR-SIDE-WEDGE-WI/124427258506?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
But how about LED for the 24/4W, indicator, and the red wedges? Anyone tried them?
Not bothered about headlamps tbh...
I have a MK2 FL VRS and not been able to find LEDs for the 501 wedges in the rear.
The holders and openings are quite small, so you will need similar sized bulbs and bases to the original
I found some LEDs that stated they were canbus compatible but the car threw a bulb out warning.
The bulbs fit the boot lights so they are in there now.
