Drop links
My 2018 mk3 VRS Combi is lowered 40mm on eibach springs. I get a slight creaking noise steering at low speed eg parking. Do I need shorter drop links?
Cheers
I wouldnt have thought so. Creaking can happen on any suspension. Might be a time to crack out the wd40 and spray all the joints to locate where it is creaking from.
Dont use wd40 on rubber bushings get a silicone spray ,wd40 destroys rubber
