Problem with SoundSystem.
Hi guys. I have a problem with my sound system, I don't know what i can to do.I didn't take the panel down. Video with the problem: https://www.youtube.com/watch?v=ltBZzm_bNh0&feature=youtu.be
Tips?
Watching your video I don't get what is the problem :(
Sir, please listen with headphones
I did... pls describe...
There is not much to describe. As you can see, it's a super weird sound, even with low bass. This sound doesn't always appear, that's weird. That's why I created this topic, maybe someone has suffered before and knows what it's about. Sorry for my eng
It's hard to tell but I think they might have distorted bass or vibration?
At a guess, you're pushing the stock speakers too hard or something in the drivers door panel is vibrating. Consider upgrading your speakers or adding sound deadening to the doors to reduce vibrations.
Thanks for the info. My problem is similar to this  https://www.youtube.com/watch?v=JuDYTsozJPQ  min 1 , repeat, sometimes it disappears
I'd suggest you do the same as the video you posted.
Remove the door card and inspect the speaker for any damage. While it's off, add some sound deadening to anything that might vibrate and refit the door card. Pretty common for anyone that's looking to improve the sound.
If you don't want to do it yourself, I'm sure a local car audio place will do it :)
 I'll try. Do you have any idea what size the speakers are? I did not find any helpful information about the 10-speaker soundsystem
  • 4 years later...
te salut,am aceeasi problema la un superb 2 2010 cu sound system,cum ai rezolvat problema?
