Unstable idling that dissapear after 1,200rpm aprox.
Hello everybody
i have some issues regarding the electrical area of my Fabia but i will post the separately and with some time of difference.
Please, check this video
https://youtu.be/32mjVz-Tl7w
Can you see how the lights on the dashboard go up and down? it does that simultaneously with the rpm change that you can hear.
Any suggestion?
Alternator?
2 hours ago, TMB said:
Alternator?
I dont know, id likt to think it is that and not a mayor problem.
I had a similar problem n anothwr vehicle, it was the alternator's regulator, it had the same simptons with the mights goinh up and down but the idle was stable.
Could it be possible the alternator is ao damaged that the irregularity in the idling could be due a resistance the alternator is creating to the engine rotation?
Yes that's exactly what I was thinking.
Omg! Please sorry for my writing, bad keyboard, the corrector in a other language and i type too fast xD.
I found the belt about to break, and some wires that goes to the pump in bad conditions (with naked wires exposed, I will first fix that and change the belt and then I will update back)
No problem :)
Problem solved!
the wires from alternator to battery and to fusebox were very bad and the connectors, replaced all that and problem gone!!
Thank you!!
  • Sponsor
Good news, well done.
The car is less likely to catch fire now I think also. :)
worried about that, just yesterday i bought two fire extinguishers, one for the trunk and a second for under my seat.
noo kidding, look!
  • Sponsor
Good idea.
On 04/12/2020 at 12:32, Kharl said:
Problem solved!
Thank you!!
https://youtu.be/ElxTct66nTk
Edited by Kharl
