skoda connect app only shows log book, trip planner and service partner options.
I was lucky, none of the all letter PIN (shouldn’t that be all letter word?) was an O.  😎
  • Replies 89
  • Views 13.5k
  • SurreySlowCoach
    SurreySlowCoach
    I'm currently running My Skoda and Connect Lite on my Karoq built in the July to November 2018 period. I have an Android phone, I use something called Hotspot Automatic that creates a hotspot when my
  • SurreySlowCoach
    SurreySlowCoach
    Finally have My Skoda working, I had to use the add vehicle, entered my Vin, it told me I already had it in the garage but then it started to work. No digital service history. Agree the manual is wors
  • SurreySlowCoach
    SurreySlowCoach
    If the connect lite app is on your phone it connects automatically using Bluetooth, you don't have to open the app. It's more solid than the my Skoda app.
May be I must have put an O then. Sorry!
Having amassed enough points on Connect Lite to activate throttle valve position, on all my journeys bar one it reads 0.0/88.2.The one journey shows 11.0/88.2. The figure to the left of the /is in bold. Does anyone know what this means?
The setting is degrees not %. Thinking back to olden days of carbs the butterfly valve would move a quarter turn or 90 degrees. I am very light on the throttle but I must open it to get anywhere.
Edited by SurreySlowCoach
Added more info
You know something about this?
5NA035284A
8 hours ago, Rajj said:
Su questo sembra essere l'unità di controllo in linea
https://www.ebay.co.uk/p/22036047039?iid=133350511720
Potrebbe essere questo quello responsabile della connettività remota !!
It have an imei and something like a coaxial connection (for aerials)
Moreover, the "C" version ( 5NA035284C ) looks like the most recent
https://www.ebay.it/i/324426747815
found this for tiguan but not for Karoq
Skoda app requires the trip screen to be active on the mobile , for the trips to record where as the Skoda lite (which is older and less advanced) does not require the app to be active to record trips- why is this regression , I wonder ?
Who knows what goes on in the mind of software engineers, I worked with them for 20 years and I never knew. I suspect the My Skoda app is designed to work brilliantly with the new models about to come off the line but alas not with anything even a few months old. I find the Connect Lite app works flawlessly on my Nov 18 build Karoq.
Couldn’t agree with you more
  • 2 months later...
With the latest update I can finally see the vehicle status and vehicle health report. As I do not have remote access in the package, I can only get to see fuel range and other stats under vehicle status.
At least some useful data in mySkoda!
Finally a little good new, i m going to update the app..
After updating, the app got stuck at the logo screen no matter how many times I tried to open it. The only way I could open is it navigate to App Store>search my Skoda > and click open.
When this happen i clear the app cache. However nice to have fuel level, hope Skoda will add the battery level
yes battery would be good. out of the 2 (vehicle status and health report) only the data for vehicle status is being held after the app is disconnected from smartlink+. vehicle health report  requires phone to be connected.
