Skoda fabia vrs 1.4 cave engine
Hi I’m currently rebuilding my engine as the second piston had been damaged. I new to this forum but would anyone know the torque specks for the head bolts, con rod bolts plus rocker cover. Much appreciated Lewis
Head bolts - (outside to inside)
Initial 30Nm all bolts
then +90 deg
then +90 deg
then +90 deg
Conrod Bolts - 30nm + 90 deg
Unsure about rocker cover, WIll check when I'm home.
Edited by Mickmartin
Thank you. Much appreciated
