Fabia mk1 water leak. Headliner wet
I have my fabia mk1. 07 plate. Yes it's had the water leaks so I sealed the door carriers etc. Despite condensation I have got to like my car.
The other day when reversing however, I noticed a damp patch on the roof liner near to the corner of the rear pillar. I pulled the liner down and there was condensation on the metal roof and the liner was like a sponge. Suspecting the drain off the sun roof I checked that they were secure and free from blockages.
As it was so damp I went when it was raining expecting to see water steaming down somewhere but nothing. Could this just be the amount of condensation ? I still suspect the sun roof in a way? Can anyone offer any help please.
What's the aerial base like?
Easiest way to diagnose it to remove the headliner, run a hose over the top and see where water is coming in.
Thank you. The head liner under the antennae is dry. I had initially thought of that. I am going to clean the rim of the sun roof to ensure no serious leak. I assume the sun roof is not totally sealed and that a little water can be accomadated and be drained away.
What happens though is the water runs along the back of the headliner (as it is a board behind) and then exits as the join with the C-pillar trim.
I will check antenna. It just looks like single bolt underneath. Is that correct? The antenna is a bit perished. Any idea where I could get a new one please?
Any help one this one please? my rear passenger foot well contains water, although there is no water on the cill. I did the door carrier seal a few years ago. So this may be an issue I need to revisit?
The main issue is the roof liner. A damp patch started at the rear drivers side corner, and its crept towards the door pillar. I have checked the drain holes from the sun roof and they look to be free. I have sponged water on the sun roof, antenna and could not see water coming in. I put it down to condensation but now think its a water leak.
During the rain today, its that back corner whats getting really wet and dripping. Can anyone suggest where else I could look please? On the roof there is the black channel that contains a small covers for the roof rack. I have never used a roof rack but do the black channels give issues? Its started very suddenly this damp issue so I would have thought I would have seen something obvious by now or water pouring in when I was testing.
Thank you for any help information.
Passenger rear footwell can be the rear wash screen wash hose. There's a joint around the rear wheelarch area.
  • Sponsor
Yep, see if you get a whiff of 'eau de screenwash' in the cabin immediately after washing (or attempting to wash) the rear screen.
Sadly no small of screen wash, although I will double check. I am sure it's rain water and I think it's sun roof. But just can't get to bottom of it with certainty.
Door carriers and threshold are dry so think that's ok.
