Dip beam and side light not working
New here !! My dip beam and side light are not working on drivers side , changed bulb twice still the same ,high beam works ,checked fuses 57 58 , taken switch out and seems fine , it's a fabia 2010 , thank you ,any help greatfully received
There are so many variants, you really need to post your engine / spec of the vehicle as well........
Anyway, also check Fuse 17 and 18 + make sure you are 100% that you have read the fuse diagram and checked correct fuses to date, it is VERY easy to miss-read...
