Late 2014 Mk3 vRS Combi Daily Driver
Hi mate. What reversing camera did you order? Do you have a link? Thanks.
Hopefully this works -https://a.aliexpress.com/_mORcqht
Camera A was perfect fit for me.
I used this thread as a reference -
Hope that helps 😊
Another AliExpress purchase - I may have a slight addiction 😂
Flappy paddle extensions 😎
Before
Paddles - I went with black as I wanted subtle rather than in your face
End result. Admittedly I've rarely used the steering controls, will see if these encourage me to use them more 🤔
Another little update - drivers foot rest. Not a perfect fit, but for €15 it's good enough 😊
One screw in the side, slight wiggling, job done. 2 mins max once I had the right torx bit.
After getting the hump waiting for a bonnet strut kit to arrive from AliExpress (ordered 27th January and should have arrived by March 4th) I went on Amazon last week and ordered the struts and ball bolts which arrived in less than a week. Fitted today which was easy as pie. Should have had an M10 spline bit for the screws in the bonnet but chanced an m8 Allen key which worked perfect. 4 screws out, 4 bolts in, click the struts in place, done 😁
Your consignment must have been shipped on the proverbial slow boat!
I like the footrest - does it require new holes to be drilled?
Nope. Hole its already in place and lines up with the original.
Indeed. And it'll probably arrive tomorrow now 😂
