Rear Indicator Bulbs
On 06/01/2021 at 12:07, Lucchese said:
Can someone confirm the rear indicator bulbs required on a 2013 pre-face lift Combi? If I search it comes up with P21W and/or RY10W, will they both fit?
Thank you
Good morning to you sir,
I always make use of auto bulbs direct for info on bulbs.
They are easy enough to use and are (for the most part) spot on.
Search for them on google sir 👍
2 hours ago, Lucchese said:
Thank you, there just is some confusion some state the PY21W and others the RY10W. I guess ill have to have a look :-)
Thank you
No worries, worse case you will literally have to pop them out and check them against images on the net 👍
