Water Ingress Passenger Front and Rear
Hi All
I have an Octavia vRS estate 14 plate (Probably not relevant!).  The floors on passenger side front and rear are wet through.  I have read through loads on here and it looks like there is a blockage in the weep hole.  I have poured water into the channels of the sunroof and drivers side clears no problem but passenger side takes ages to clear.  Would compressed air work down the holes?  If not, I assume its a remove liner to access pipes - if so how is this done?
Thanks in advance.
Thanks Ords for your help with that.  It was certainly gunked up and water now flows to where it should be doing.  However, it is also still leaking.  Could it be that any pipework could've split given the recent heavy frost?  I ran water into the drainage as suggested and water is exiting in the car under the glovebox as well as into the bulkhead in the engine area as Bigjakk mentioned.
If it has split or come loose how do I gain access to it?
Any help appreciated.
Another couple of links.
Problem solved.  I 'de-gunked' the nipple in the bulkhead after removing the Plenum Chamber cover.  As said above, partial solution, so then removed the pillar trim above the glove box to expose the pipe.  It had come loose from the rubber nipple thing - some water was going were it should be more was spilling out. Reconnected the pipe by pushing it back in and hey presto.  Problem solved.  Not sure how or why the pipe had come loose from the nipple - maybe a build up of gunk along with excess water but seems ok.  Couldn't decide whether I should've glued the two together, but didn't.  Lets see how long it lasts!
