DSG Issues 2012 1.2 ... Few Questions
Hi Guys,
My father in laws mk2 fabia 1.2 dsg as part failed today. Car only has 38k miles on the clock.
I wonder if i could quiz you kind folk?
The car was driving fine, then went to turn around and realised he had no reverse gear. He's lost 2nd +4th and reverse gear and can only operate the car in manual. They managed to limp the car home and now parked up. I haven't had change to have a scout at it yet.
But no noises or indication of a fault prior. Just loss of gears and no flashing errors on the dash.
After some research, i just wanted to confirm a few things and possibilities. I heavily suspect a mechatronic fault.
Seems a big issue is a leaking accumulator housing within the mechatronic unit...
  • As understand the mechatronic housing sits outside the gearbox right?
  • Can the accumulator housing be repaired using a repair kit in position on the car without removal of the whole mechatronic?
  • What odb scanner do we need to interrogate the DSG faults?
  • Any other tests to confirm the fault?
Any help would be appreciated guys! Thanks in advance!
You need VCDS or similar to scan the DSG properly.
