Superb 2021 Scandinavian DRLs error
Anyone else had this issue?
I used obdeleven app to enable Scandinavian DRLs (I.e. rear lights on with DRLs)
tgat worked fine
but, I now have two errors on the cars screen and binnical
“check rear fog light left hand side”
and
”check rea fog light right hand side”
checked and the right hand (only fitted) is working OK
so has anyone else had this or a work around? If not I will remove the Scandinavian DRLs change
thanks
How did you change the coding?
Manually or with the one click function?
With the one click option
Thats more than likely the issue then, there are many reports of the one click option changing additional coding that doesn’t need changing.... and not un coding it all again if you revert back to standard.
This is the reason why ALL coding should be physically changed by 'long coding’ or ‘adaptations’ and not the one click method.
So, what’s the options? Reset to factory and start again?
You can try... but as I said previously it may not go back to how it was.
I believe that OBDeleven has a 'history' file somewhere and can also make a 'backup' of the adaption channels. Are you able to find/create these and post them?
If we can see how your car is currently configured and ideally what changes have been made, we should be able to get you sorted :)
Many thanks langers2k, Inwill do a check.
changes in order were
1) DRL with stripes
2) ‘coming hone lights via fog lights
3)  start button pulse
4)  Scandinavian DRL
5) Throttle response.
I will get the date from obdeleven
This is the history. Can’t seem currently to find the backup, well, it’s not where it shoukd have been
I will do one now
And this is the history txt
OBDeleven vehicle history log
Date: 2021-02-02 11:26
    VIN: TMBKN7NP7M7035124
    Car: Skoda Superb
    Year: 2021
    Body type: Estate
    Engine: DPCA
    Mileage: 133 KM
Fault
    Control unit: 01 Engine
    Active faults: 0
    Inactive faults: 0
    System description: R4 1.5l TFS
    Software number: 05E906018CS
    Software version: 0809
    Hardware number: 05E907309H
    Hardware version: H20
    ODX name: EV_ECM15TFS01105E906018CS
    ODX version: 004003
    Faults:
        No trouble codes found
    Mileage: 133 km
    Date: 2021-02-01 13:51
Fault
    Control unit: 02 Transmission
    Active faults: 0
    Inactive faults: 0
    System description: GSG DQ200G2_M
    Software number: 0CW300027M
    Software version: 2202
    Hardware number: 0AM927769N
    Hardware version: H07
    Serial number: CU502011077889
    ODX name: EV_TCMDQ200021
    ODX version: 001001
    Faults:
    Mileage: 133 km
Fault
    Control unit: 03 Brakes
    Active faults: 0
    Inactive faults: 0
    System description: ESC
    Software number: 5Q0614517GD
    Software version: 0114
    Hardware number: 5Q0614517BR
    Hardware version: H82
    Serial number: 63140000003938
    ODX name: EV_Brake1UDSContiMK100IPB
    ODX version: 049015
    Faults:
    Mileage: 133 km
Fault
    Control unit: 08 Air Conditioning
    Active faults: 0
    Inactive faults: 0
    System description: AC Automat
    Software number: 3V0907044FK
    Software version: 4901
    Hardware number: 3V0907044FK
    Hardware version: H34
    Serial number: 00000B01783820
    ODX name: EV_ACClimaPrehVW37X
    ODX version: 002030
    Faults:
    Mileage: 133 km
Fault
    Control unit: 09 Central Electrics
    Active faults: 0
    Inactive faults: 2
    System description: BCM MQBAB M+
    Software number: 5Q0937084DP
    Software version: 0411
    Hardware number: 5Q0937084DP
    Hardware version: H42
    Serial number: 01102031900414
    ODX name: EV_BCMMQB
    ODX version: 021001
    Faults:
        B121F15 - Left fog light bulb Open circuit/short circuit to B+
            Intermittent
                Date: 2021-02-01 13:44:04
                Mileage: 133 km
                Priority: 4
                Malfunction frequency counter: 1
                Unlearning counter: 56
                Terminal 15 status: On
                Terminal 50 status: Off
                Voltage: 13.2 V
                Outside air temperature: 6.5 °C
                Status Bremslichtschalter (HW): Off
                Status Bremslichtschalter (CAN): Off
                Off: not activated
                Parking light: not activated
                Automatic high beam assist: operated
                Low beam: not activated
                Parking light left: not activated
                Parking light right: not activated
                Letzte Weckursache/ Werte [00;2E]: Pin C14 Kessy Weckleitung
                CAN-Bus_aktiv: On
        B122015 - Right fog light bulb Open circuit/short circuit to B+
            Intermittent
                Mileage: 133 km
                Priority: 4
                Voltage: 13.2 V
                Off: not activated
                CAN-Bus_aktiv: On
    Mileage: 133 km
Fault
    Control unit: 13 Adaptive Cruise Control
    Active faults: 0
    Inactive faults: 0
    System description: ACC BOSCH MQB
    Software number: 5Q0907572S
    Software version: 0780
    Hardware number: 3Q0907567A
    Hardware version: H02
    ODX name: EV_ACCBOSCHVW416
    ODX version: 003015
    Faults:
    Mileage: 133 km
Fault
    Control unit: 15 Airbag
    Active faults: 0
    Inactive faults: 0
    System description: AirbagVW21
    Software number: 5Q0959655CF
    Software version: 0421
    Hardware number: 5Q0959655CF
    Hardware version: 008
    Serial number: 003J8R6U311C
    ODX name: EV_AirbaVW20SMEVW37X
    ODX version: 002166
    Faults:
    Mileage: 133 km
Fault
    Control unit: 17 Dashboard
    Active faults: 0
    Inactive faults: 0
    System description: KOMBI
    Software number: 3V0920950F
    Software version: 8400
    Hardware number: 3V0920950F
    Hardware version: 303
    ODX name: EV_DashBoardVDDMQBAB
    ODX version: 009071
    Faults:
    Mileage: 133 km
Fault
    Control unit: 19 Gateway
    Active faults: 0
    Inactive faults: 0
    System description: GW MQB High
    Software number: 3Q0907530AG
    Software version: 5423
    Hardware number: 3Q0907530C
    Hardware version: 521
    Serial number: 13112010801321
    ODX name: EV_GatewNF
    ODX version: 013026
    Faults:
    Mileage: 133 km
Fault
    Control unit: 23 Brake Boost
    Active faults: 0
    Inactive faults: 0
    System description: EBKV
    Software number: 3Q0909059AA
    Software version: 0074
    Hardware number: 3Q0909059A
    Hardware version: H06
    Serial number: BPA08513102001302543
    ODX name: EV_BrakeBoostG2BoschVW48X
    ODX version: 012121
    Faults:
    Mileage: 133 km
    Date: 2021-02-01 13:52
Fault
    Control unit: 2B Steering Column Lock
    Active faults: 0
    Inactive faults: 0
    System description: ELV-MQBB
    Software number: 2Q0905861B
    Software version: 0040
    Hardware number: 2Q0905861B
    Hardware version: H09
    Serial number: 20000265920005
    ODX name: EV_ELVMarqMQBA0
    ODX version: 002004
    Faults:
    Mileage: 133 km
Fault
    Control unit: 36 Driver Seat
    Active faults: 0
    Inactive faults: 0
    System description: Sitzmemory
    Software number: 5Q0959760F
    Software version: 0026
    Hardware number: 5Q0959760F
    Hardware version: H10
    Serial number: Y0007TK434809
    ODX name: EV_SeatMemorDriveSide
    ODX version: 002022
    Faults:
    Mileage: 133 km
Fault
    Control unit: 3C Lane Change Assistant Right
    Active faults: 0
    Inactive faults: 0
    System description: HRE3_Kl15_Mst
    Software number: 2Q0907686B
    Software version: 0150
    Hardware number: 2Q0907686B
    Serial number: 14520004959656
    ODX name: EV_HREntryHellaGen3Kl15
    ODX version: 002001
    Faults:
    Mileage: 133 km
Fault
    Control unit: 42 Driver Door
    Active faults: 0
    Inactive faults: 0
    System description: TSG FS
    Software number: 5Q4959593N
    Software version: 0820
    Hardware number: 5Q4959593N
    Hardware version: 010
    Serial number: 0000425803651
    ODX name: EV_DCU2DriveSideMAXHCONT
    ODX version: 001005
    Faults:
    Mileage: 133 km
Fault
    Control unit: 44 Steering Assistance
    Active faults: 0
    Inactive faults: 0
    System description: EPS_MQB_ZFLS
    Software number: 5Q0909144AB
    Software version: 1082
    Hardware number: 5Q0909144AA
    Hardware version: 130
    ODX name: EV_SteerAssisMQB
    ODX version: 015157
    Faults:
    Mileage: 133 km
Fault
    Control unit: 4B Multifunction Module
    Active faults: 0
    Inactive faults: 0
    System description: FCM MQB Low
    Software number: 3Q0907338E
    Software version: 0367
    Hardware number: 3Q0907338E
    Hardware version: 003
    Serial number: 07112011600203
    ODX name: EV_MultiModulContiVW48X
    ODX version: 003003
    Faults:
    Mileage: 133 km
Fault
    Control unit: 52 Passenger Door
    Active faults: 0
    Inactive faults: 0
    System description: TSG BFS
    Software number: 5Q4959592N
    Hardware number: 5Q4959592N
    Serial number: 0000426252025
    ODX name: EV_DCU2PasseSideMAXHCONT
    ODX version: 001005
    Faults:
    Mileage: 133 km
Fault
    Control unit: 5F Multimedia
    Active faults: 0
    Inactive faults: 0
    System description: MU-O-ND-EU
    Software number: 3V0035820D
    Software version: 0270
    Hardware number: 3V0035820D
    Hardware version: H22
    Serial number: SKZAZ2X0658593
    ODX name: EV_MUOIMQB
    ODX version: 001001
    Faults:
    Mileage: 133 km
Fault
    Control unit: 6D Deck Lid Control
    Active faults: 0
    Inactive faults: 0
    System description: HDSG-Modul
    Software number: 5WB959107
    Software version: 0430
    Hardware number: 5WB959107
    Hardware version: H04
    Serial number: A2-C767-1200-5
    ODX name: EV_DeckLidCONTIAU536
    ODX version: 001001
    Faults:
    Mileage: 133 km
Fault
    Control unit: 75 Telematics
    Active faults: 0
    Inactive faults: 0
    System description: OCUGen3High
    Software number: 5WA035284B
    Software version: 0035
    Hardware number: 5WA035284B
    Serial number: 0000000010VIDN703114
    ODX name: EV_OCUGen3High
    ODX version: 003005
    Faults:
    Mileage: 133 km
Fault
    Control unit: 76 Parking Assistance
    Active faults: 0
    Inactive faults: 0
    System description: PDC 8 Kanal
    Software number: 5QA919294J
    Software version: 0073
    Hardware number: 5QA919294
    Hardware version: H08
    Serial number: 00015005832031793640
    ODX name: EV_EPHVA18AU3700000
    ODX version: 009053
    Faults:
    Mileage: 133 km
Fault
    Control unit: A5 Driver Assistance
    Active faults: 0
    Inactive faults: 0
    System description: MQB MFK 3.0
    Software number: 2Q0980653B
    Software version: 1202
    Hardware number: 2Q0980653
    Hardware version: H13
    Serial number: E5782951220302001091
    ODX name: EV_MFK3ValeoMQB
    ODX version: 007042
    Faults:
    Mileage: 133 km
Fault
    Control unit: B7 Start System Interface
    Active faults: 0
    Inactive faults: 0
    System description: VWKESSYMQB
    Software number: 3Q0959435N
    Software version: 1307
    Hardware number: 3Q0959435N
    Hardware version: 037
    Serial number: 0561263280
    ODX name: EV_KessyHellaMQBAB
    ODX version: 004052
    Faults:
    Mileage: 133 km
Fault
    Control unit: BB Rear Left Door
    Active faults: 0
    Inactive faults: 0
    System description: TSG HFS
    Software number: 5Q4959595N
    Hardware number: 5Q4959595N
    Hardware version: 007
    Serial number: 0000424904770
    ODX name: EV_DCU2RearDriveMAXHCONT
    ODX version: 001005
    Faults:
    Mileage: 133 km
Fault
    Control unit: BC Rear Right Door
    Active faults: 0
    Inactive faults: 0
    System description: TSG HBFS
    Serial number: 0000425587535
    ODX name: EV_DCU2RearPasseMAXHCONT
    ODX version: 001005
    Faults:
    Mileage: 133 km
Fault
    Control unit: D6 LED Module Left
    Active faults: 0
    Inactive faults: 0
    System description: LED1L
    Software number: 992941571AA
    Software version: 9002
    Hardware number: 992941571A
    ODX name: EV_LLPGen3LKEBODPO68X
    ODX version: 001003
    Faults:
    Mileage: 133 km
Fault
    Control unit: D7 LED Module Right
    Active faults: 0
    Inactive faults: 0
    System description: LED1R
    ODX name: EV_LLPGen3RKEBODPO68X
    ODX version: 001003
    Faults:
    Mileage: 133 km
    Date: 2021-02-01 13:53
I will have another look, I didn’t see tgat view in eitger iOS or android..
I will link to the car and see if that changes it
thanks
Right.
looks like  I was blaming the Scandinavian DRL one touch application wrongly.
still had the rear fog light error even after uninstalling the scandinaviannDRl app.
so, I then removed
1) DRL with sripes
2) coming home lights via fog
3)DRL settings in head unit
 And surprise, the error has gone away.
so now to find out which of the three is causing the rear fog light errors
I’d suggest a better use of time would be just leaning how to do these changes yourself.  None of the ones you’ve listed are particularly difficult to achieve. Ditch the one touch apps.
  • 4 months later...
On 04/02/2021 at 17:24, Warkman said:
Right.
so, I then removed
1) DRL with sripes
Hi mate I was looking at the post and just wondered I'm thinking of doing the same to my Skoda Octavia mark 3 which I bought last year it is a brand new car and I was thinking of putting on this Scandinavian lighting obviously I will buy a obd11 just out of interest did you get all your issues sorted out it looks a bit scary to me there are only two things I need to do on my car are turn the stop and start off  put on Scandinavian drl all advice would be thankful and should I buy the pro version or just the basic version of the obd11 not going to be doing a lot of coding or anything like that that thanks a lot
Skoda (actually VAG) have disabled all the known tweaks that disabled stop/start - because of dieselgate and WLTP issues.
Yes, the issue was stripes with DRL, in fact OBD11 have removed that one touch application, so it seems the issue is there
I got a mark 3    is this new for the mark 4 that prevent you from deleting stop and start but I'm sure somebody somewhere will be able to put a code in in the near future thank you for your input
It's from around MY19 or MY20 if I remember correctly rather than during a model change 😕
Many have looked, none have found a method yet...
Yes, even the later Mk3 Octavia cannot have stop/start disabled.
My was built on  31.9 .2019 hopefully there will be a work around in the future thank you for letting me know:blink:
Ok then I will leave you for a little while just curious what do you mean by stripes what does that exactly mean I'm just interested so at this present moment cannot turn on Scandinavian drl and cannot turn off stop and start on this present car help me in the future somebody like a oBD11 will work around it much happier now I know where I stand
