CAR JUDDERING
Hi everyone.
I have a skoda octavia vrs cr 170
When I was on the drive home tonight.
I was in 3rd gear doing 30 mph then  started to accelerate up go 40mph before I got to 40mph it started to juddering abit and was hesitant. Any ideas?
How many miles, when was last service, has clutch ever been changed.
Could be a few things, spark plugs, coil pack, build up of carbon somewhere.
Can you scan ECU for fault codes?
84k
Last service 79k
Original clutch I believe.
Going to try get in a garage tomorrow to scan.
when it happened no light come up on dash.
Wheelspin?
Failing dual mass flywheel?
Hmm.
How would I find out if it is?
5 hours ago, pikpilot said:
For a comprehensive answer take a look at:
https://www.eeuroparts.com/blog/dual-mass-flywheel/#:~:text=A fully functioning DMF will,clutch and apply the gas.
Basically, you look for judder when you put the transmission under medium load or listen for noises when idling. Can also be felt as a judder when accelerating.
Doesnt really sound like what's described in the link. Getting scan tonight hopefully might have a  code
@Benskoda170cr Any news??????????? when was the fuel filter changed / has it been????????
And has the car been used much recently or been stood for ages??????
Hasn't done the shuddering since.
Scanned for codes no code.
Used every day.
Service booked to change all filters.
just a glitch then hopefully............. Aliens in the machine as they say.
Mine has done it on a couple of occasions but only once in a blue moon.
Edited by Tilt
Yeah could be one of them things. Maybe a bit of dodgy fuel. It's done it twice in like 5 months
I can second,  mines done it too occasionally think maybe 4 times in as many years
