vRS blackline amundsen+ Bluetooth help!
I am looking for info, I have a 2012 Octavia vRS black which has the amundsen+ radio, am I right in saying that I just need to purchase a microphone to connect to enable phone connection ? Do they already have the module? Looking at the MAC address on the unit it has lots of different numbers and not zeros.
I have someone with vcds who can enable the system.
Any info/links to an up to date seller etc would be amazing.
Sorry if this has already been asked.
Welcome :)
Plenty on eBay if you look for RNS 315 mic. The only obvious UK seller is this one: https://www.ebay.co.uk/itm/203128544900
There are some in Europe and China for cheaper but it'll depend how quickly you want it to arrive ;)
Given the mac isn't 00:00:00:00:00:00, that suggests it has a BT module built in and just needs activating. You can also activate BT before you fit the mic as your phone should connect but obviously nobody will hear you on calls :D
14 minutes ago, langers2k said:
Welcome :)
Hello🙂and thank you for the welcome!
The link is perfect thank you, I had no clue what I was looking for.
It’s been so frustrating to have a Bluetooth button and it do zilch😒 I’m assuming it’s just a case of using the vcds to activate the Bluetooth 🤞🏻
