lowered mk3 vrs xenon headlights reset
hi guys
I have a full version of vcds just lowered my mk3 vrs 2015, but need to know how to recalibrate the xenon headlights.
 it has the self adjusters on the front lower arms and the rear arm.
Does it reset it's self?
if not has anyone got a guild please.
Thanks.
[Select]
[55 - Xenon Range] (For some newer vehicles,  use [29 - Left Light] instead )
[Basic Settings - 04]
Group 001
[Go!]
Wait at least 20 seconds for the headlamp motors to move. The headlamps are now in their adjustment position. Turn on headlights. Adjust them via their manual adjusting screws as referenced against a suitable aiming target.
Scroll up to Group 002. The Xenon Range controller has now learned this position as its Home position.
Click the [Done, Go Back] button and you're all set.
Note: There have been reports of lowered vehicles displaying an error message in either Basic Settings group 001 or 002. If the vehicle height sensor(s) are bottomed out, it may be necessary to bend the sensor bracket to allow normal adjustment to occur. Also, check to make sure that the sensor arms do not have their pivots facing the wrong direction as shown in this thread: http://forums.vwvortex.com/zerothread?id=2383036
Copied from Ross Tech
Thankyou didn't know I needed to adjust the manually.
