Octavia 1z3 pre-fl one touch window and door opening sensor
Got an issue with my octavia 2008 1z3 pre-face lift.
The driver side door one touch function stopped working at the same time as the sensor that detects when the door is open.
The weather has been really cold recently (below -10°C). One morning I accidentally pressed the auto open button, the window opened half way before I stopped it.
And that's how it happened, both functions just stopped working. The window still opens/closes fully and normally, however the auto function doesn't work. Also the mentioned sensor doesn't work any more either.  I don't see how these two are related based on the stuff I read on the forum.
All doors lock/unlock normally. Also the one touch function on all three other doors works normally.  Opening other doors is detected by the car as well.
The weather is now above 0°C if it matters.
any suggestion is appreciated
many thanks
Sounds like it could be a broken wire in the rubber bellows between body and door, the driver's door getting the most use and cold temperatures weakening 12 year old wires.
Try wiggling bellows/wires to see if open door alert  displays.
Edited by MicMac
Tried it this morning, wiggled the wires vigorously but nothing happened on the dashboard. Although, the one touch function started working again after performing the reset procedure.
However the door sensor issue still remains.
After experimenting a bit I have realised that when I pull the door opening handle very slowly from the inside and in the moment when the door "pops" open, it will detect the opened door for a fraction of a second.
I guess the issue with that is the microswitch mentioned in other places in the forum?
