Resetting Service Indicator
Hi all, had the Octy RS serviced a couple of weeks ago by a non VAG dealer. Can I use VAG-Com to reset the service light?
Thanks Richie
PS Im on variable and want to keep it that way
Sure, VAG-COM works like the dealer tool here. Just use cluster > adaptation channel 002 to reset it, it will keep the flexible intervals - you may check that afterwards in channel 45.
Thanks a lot, Ill try that tomorrow.
Kind Rgds
Rich
Hi,
Unfortunately I cant get that to work. 002 is not a valid channel it says so I tried 02.
Read = 128
Click TEST = ERROR
Am I doing something wrong?
Its a 2003 Octavia vRS
Richie
17 dash
10 adaptation
channel 02 reset to zero and save
Dont know where you are with that readout.
