Fabia fault, any advice greatly appreciated.
Hi there,
I have an 2012 12v fabia 1.2L which is giving the error code P210100 - Throttle actuator control motor circuit range/performance.
The car is isn’t drivable as it can’t accelerate to anything above 5mph.
Had the below done:
Ecu tested - checked ok
Throttle control module replaced
engine wiring loom replaced due to some broken wires.
The car has had a new battery also.
Any advice or ideas would be greatly appreciated as I’m at a total loss.
Thanks in advance.
Was the throttle body or the throttle pedal replaced, because whichever one was done, it's the other one that needs doing.
