MAS Air Filter Sensor
Hi-
need advice   & help with my Skoda Octavia 1.6 petrol MPI- year 2011
Got code P0170 on UB Reader-
Looking through forums - need extra advice-
It  says car running lean -air & fuel mixture problem- need to try and clean sensor with Maf Air Cleaner- got today in Halfords-
Any help to remove and clean please- what & how to do this job- diy if possible-
Kind regards/Thank you
Tony-Dublin-Ireland:crying:
normally if its the maf you get a lumpy idle where it doesnt settle down.
im not familiar with the 1.6mpi, but removing the maf is normally pretty easy - disconnect the jubilee rings (or similar) either side of it and unplug the cable. if youve never done anything with vag wiring have a quick look on youtube on how to disconnect the plugs, theres a knack to it.
then youll have your maf and follow the instructions on the cleaner ypu got :)
welcome to brisky from Tipp, btw ;)
