This looks bad
Car Scanner ELM OBD2
DTC report
Selected brand: Skoda
VIN: TMBFK25J8E3014011
============1==============
P0405
Raw code: 0405
ECU: Engine control unit
Status: Pending
OBDII: Exhaust gas recirculation (EGR) valve position sensor A - low input
Skoda: Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
============2==============
15536
Raw code: 003CB0
Status: Test failed (current drive cycle), Pending, Test failed since last DTC clear
============3==============
15536
Raw code: 003CB0
ECU: 19. CAN Gateway
============4==============
15536
Raw code: 003CB0
ECU: 01. Engine control unit
Is your car a 2013 Fabia? - This is the Mk3 (2015+) forum page.
But you're fault looks like an EGR Failure. You will need to get it booked into the garage.
