Chinese android radio and OEM BT microphone with swing?
Hi does anyone here have wiring diagram or photos how is oem bluetooth microphone wired?
2011 octavia with swing radio and bluetooth
I would like to use oem BT microphone with aftermarket chinese android unit.
I think it goes to under the driver's seat. Don't think it does to the back of the stereo. Should just be a 2 wires + & -
I didn't have an OEM microphone so I bought a Fiscon that fits I to the OEM slot in the interior light but has a standard 2.5mm socket that plugs straight my Android radio.
As Phil-E mentioned, with a Swing and BT module, the mic will likely go directly to the BT module.
At a guess:
- BT module: pin 11 mic +
- BT module: pin 12 mic -
The only exception would be when a RNS-510 Columbus with voice control is fitted. The mic would connect to the headunit then there is an extra pair of wires between the headunit and BT module :)
